0 members (),
330
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Does anyone know if the bigger AD truck radiators were different from the pickups?
I recently bought a fan shroud designed to accommodate late 235s with the low-mount water pump in AD pickups. It doesn't fit mine.
It came in just a few days and says on the box for 18-1/2 X 20 inch radiators. My radiator is 19-1/2 inches wide. Were big truck radiators wider or has the vendor or me made an incorrect assumption? I got the radiator from a bone yard decades ago and it was marked "54 ton and a half", it's way thicker with bigger tanks than the original in my 1-ton pickup. I used it for a decade or more till it leaked too bad then had it recored. The shroud is a good idea and accommodates the fan which extends below the radiator frame. But with my 18-inch fan I can't just modify the brackets and let some of the radiator be outside the shroud.
Just a head's up for guys with 18-1/2" X 20" radiators and smaller fans, these things exist, are available from Vintage Air and the price is right. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Mar 2014 Posts: 4,509 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,509 | The 1/2, 3/4, 1 and 1 1/2 ton radiators were all the 15 quart. And then the 2 ton was larger at 17 quart...from the shop manual, anyway. Hope it helps. I have a shroud I got from Old Air Products in Ft Worth and that is an excellent product. Heavy aluminum and made to last forever.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
