3 members (50Chevy3100, 2 invisible), 64 guests, and 6 robots.
Topics128,180
Posts1,057,145
Members48,463
This is prbably old as dirt but I just found it.
I have a freind that works for a motor home company. They build motor homes. Well a lot of wiring go's into these motor homes so they use numbered wiring. They have a machine that intalls numbers onto the wiring. Thats cool enough but not what I found. The thing is that some times a wire will have to be replaced. When that happens they have little rolls of numbered tape inside a container and they go from "0" to "9" you just open the container for the desired number and peel off an inch or so of tape to stick to your wire.
This stuff is great for numbering your wiring when doing a restore that may be apart for months or years. You can find it at an electrical supply store. The rolls of tape are not very long but you can buy refills for the numbers you need. Way cool stuff.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
Good for vacuum line disassembly, or anything else you need to mark. I think 3M carries a version. Another method is to use colored ty-wraps. We use a lot of those for boom disassembly.
If you have a photographic memory like Rusty Rod, then you dont need anything...
eh... (6 years later) I wonder where this wire goes?
Another quality post.
Real Trucks Rattle
U dug up a old one that time Jeff.
I've got a set of those markers made by 3M. Rewired a '53 I had from scratch and used them heavily.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
u can probably pick them up at an electrical supply store.Most electricians use them.
There's a lot to choose from. I bought Panduit when I was buying for a communications shop. Like I said, there's a lot out there.
She's one 55 year old with a spare tire that looks good!
It's not rocket surgery. . . .
http://www.picturetrail.com/fredoly
http://www.cardomain.com/ride/2412127
Moderated by  MNSmith
