7 members (39Master85, kades51, Dennys28, baldeagle, Hotrod Lincoln, Otto Skorzeny, dt235sd),
73
Mod | | | Forums66 Topics128,180 Posts1,057,149 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | This is prbably old as dirt but I just found it. I have a freind that works for a motor home company. They build motor homes. Well a lot of wiring go's into these motor homes so they use numbered wiring. They have a machine that intalls numbers onto the wiring. Thats cool enough but not what I found. The thing is that some times a wire will have to be replaced. When that happens they have little rolls of numbered tape inside a container and they go from "0" to "9" you just open the container for the desired number and peel off an inch or so of tape to stick to your wire. This stuff is great for numbering your wiring when doing a restore that may be apart for months or years. You can find it at an electrical supply store. The rolls of tape are not very long but you can buy refills for the numbers you need. Way cool stuff.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Oct 2005 Posts: 4,260 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,260 | Good for vacuum line disassembly, or anything else you need to mark. I think 3M carries a version. Another method is to use colored ty-wraps. We use a lot of those for boom disassembly. | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | If you have a photographic memory like Rusty Rod, then you dont need anything...
eh... (6 years later) I wonder where this wire goes?
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | U dug up a old one that time Jeff. | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | I've got a set of those markers made by 3M. Rewired a '53 I had from scratch and used them heavily.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | u can probably pick them up at an electrical supply store.Most electricians use them. | | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | There's a lot to choose from. I bought Panduit when I was buying for a communications shop. Like I said, there's a lot out there. | | |
