| | | Forums66 Topics128,169 Posts1,057,041 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | Is the clutch release bearing the same for either a 3 speed or a 4 speed?
My pickup has a Muncie SM420 that I am looking for the proper clutch release bearing.
Walt Longmont, Co.
| | | | | Joined: Jan 2022 Posts: 2,483 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,483 | You don't state year, make or model of your pickup, but just in case, the 1939-53 GMC Master Parts Book calls for the same clutch release bearing for all 1/2 ton thru 2 ton trucks no matter which transmission. Part number is 909422. Same part number is listed in the 1929-54 Chevrolet Master Parts Catalog for "all" 1938-54.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/12 '52 GMC 152 Stake Bed, Original 228, SM420, added A/C, HEI, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
| | | | | Joined: Jan 2022 Posts: 2,483 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 2,483 | National 614037. RockAuto has it for $41.79
Also SKF N1086SA and Timken 614037.
| | | | | Joined: Jun 2022 Posts: 558 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 558 | Beware... the bearing they stick in a "clutch kit" is usually an offshore piece of junk. Get one of the above suggested bearings. I hate having to pull a transmission because the throwout bearing has failed.
~~ Jethro 1954 3100Back to LifeIn the Dity Gallery1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020 | | |
