0 members (), 93 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
Is the clutch release bearing the same for either a 3 speed or a 4 speed?
My pickup has a Muncie SM420 that I am looking for the proper clutch release bearing.
Walt
Longmont, Co.
You don't state year, make or model of your pickup, but just in case, the 1939-53 GMC Master Parts Book calls for the same clutch release bearing for all 1/2 ton thru 2 ton trucks no matter which transmission. Part number is 909422. Same part number is listed in the 1929-54 Chevrolet Master Parts Catalog for "all" 1938-54.
National 614037. RockAuto has it for $41.79
Also SKF N1086SA and Timken 614037.
Beware... the bearing they stick in a "clutch kit" is usually an offshore piece of junk. Get one of the above suggested bearings. I hate having to pull a transmission because the throwout bearing has failed.
~~ Jethro
1954 3100
Back to Life
In the Dity Gallery
1951 3100 (gone) / 1956 4400 (still in the neighborhood) / 1957 6400 with dump body (retired) / 1959 3100 panel (in the woods junked) / 1978 Custom Deluxe K10 / 1993 S-10 4.3 / 2004 Chevy Crew Cab / 1945 John Deere H / 1952 John Deere B / 1966 John Deere 2510 / 1967 John Deere 1020
