7 members (gswbbc, TUTS 59, jmoore, Brian Moore, tclederman, Steelonsteel, BC59),
82
Mod | | | Forums66 Topics128,031 Posts1,055,435 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 17 'Bolter | | 'Bolter Joined: Mar 2015 Posts: 17 | I've installed a SBC in my 65 truck and the valve covers are touching the firewall. I have the perches in the back holes which I think was told that this is the correct location for the v8. What would be the problem with using the front two holes? Looks like it would give me about two inches more away from the firewall. What perches have someone used and would recommend? | | | | | Joined: Feb 2004 Posts: 29,749 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,749 | As long as you're willing to alter the driveshaft length to compensate, I don't see a reason not to make the engine happy and adapt everything else to fit. Jerry
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | If this is a manual transmission application, you may be using the incorrect bellhousing. The truck bellhousing has one hole on each side located at about a 45 degree angle to match the cross member. The early car bellhousings had 2 holes on each side and used a completely different mount configuration. Fred
