8 members (dt235sd, Lonnie, Wickedbass, Gabes-trucks, Ponchogl, Otto Skorzeny, 2 invisible), 193 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#1584287 08/04/2025 4:10 PM
If you have to replace your tie rod ends and get the new replacement like these, 47-59
Plan on replacing the tightening bolts. To keep the steering rod so that the tie rods are rotating together.
The force needed to clamp down 3x`s now destroyed the bolt threads. Just inferior thread strength.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
I have a friend (perfectionist and machinist) who removed his tie rod, bored out a nut big enough to be a slip fit onto the tie rod and welded it onto the tie rod near the driver's end. That way you can use an open end wrench while adjusting toe in/out instead of leaving teeth marks from a pipe wrench/channel lock pliers on the tie rod.
That would solve it. Its bad enough the nut and bolt are 17mm.
~ BD.
