2 members (texczech, 78buckshot), 110 guests, and 6 robots.
Topics128,078
Posts1,056,035
Members48,433
#1584241 08/04/2025 1:51 AM
Anyone have any pics of the rod from carburetor to the bell crank swivel? I have a 235 with Fenton headers and the rod that’s on now gets stuck
This is no longer fun
Sorry I couldn't get a better picture. The rod from the carb. passes down between the intake/exhaust (Fenton) manifolds and the engine block and then connects to a swivel mounted on the side of the block. From there it connects to the linkage of accelerator pedal.
1956 3100 three speed 6 cyl. Stock with a few upgrades.
Looks good did you make the rod or buy the rod I like the clips that hold it on
It happens that I have a 235 with a Carter Carb on the floor. Attached are photos of the rod as installed and on the tacble. Hope this is what your' looking for
That style clip should be available at your local parts store.
The Fentons are the problem, not the linkage. You'll probably have to do a little custom bending with a torch and a pry bar.
Thanks for the pics and HRL don’t have a torch so will have to muscle it I guess
Going to try and post a pic
Going to try another
Thanks for pic Btw what’s the easiest way to post a pic
AD Addict & Tinkerer
Here’s a link to instructions on how to add pictures to a post.
Phil
Project Journals
Stovebolt Gallery Forum
Thanks for the info
