1 members (Bill Hanlon), 167 guests, and 2 robots.
Topics128,196
Posts1,057,386
Members48,471
Does anyone have shape and dimentions of the front and rear fender braces for 1948 Chevy ½ ton?
I have some of the braces but I can't decipher which is which.
If you're talking about the rear braces that go at the crown of the fenders, they're identical so not side specific. They attach to the fenders with semi-tubular rivets. (PM me if you want a few) The big stamped steel braces for the front fenders should be obvious which side they go on.
The rod braces at the rear of the front fenders have a pretty hard bend at the hole that goes to the cowl bolts, and are side specific. Clean up the ends real well and look for stamped "R" and "L" on one of the ends. Same for rear fender rod braces, but they don't have as severe a bend. I believe on the 1/2 ton they bolt to the bottom frame flange. In either case it's mostly hold them in position to see if they fit correctly.
