3 members (Gdads51, UtahYork, 1 invisible),
109
Mod | | | Forums66 Topics128,191 Posts1,057,364 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 270 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 270 | Does anyone have shape and dimentions of the front and rear fender braces for 1948 Chevy ½ ton?
I have some of the braces but I can't decipher which is which. | | | | | Joined: May 2015 Posts: 11,181 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,181 | If you're talking about the rear braces that go at the crown of the fenders, they're identical so not side specific. They attach to the fenders with semi-tubular rivets. (PM me if you want a few) The big stamped steel braces for the front fenders should be obvious which side they go on.
The rod braces at the rear of the front fenders have a pretty hard bend at the hole that goes to the cowl bolts, and are side specific. Clean up the ends real well and look for stamped "R" and "L" on one of the ends. Same for rear fender rod braces, but they don't have as severe a bend. I believe on the 1/2 ton they bolt to the bottom frame flange. In either case it's mostly hold them in position to see if they fit correctly.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
