8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible), 58 guests, and 1 robot.
Topics128,049
Posts1,055,699
#1583940 07/31/2025 2:48 PM
I am preparing to install glass in my '50 3600 and have a few questions that I am hoping will ease the process.
When installing the glass into the rubber how do people get the last corner of the glass into the groove? As shown in the attached I have the glass into the groove most of the way around but I can not seem to stretch the rubber enough to get the last corner installed. Is there a trick or process to getting enough flexability in the rubber to stretch it over the last corner?
I inserted rope into the pinch weld channel on the rubber but I am concerned that the rope I have is too large a diameter, it basically fills the groove for the pinch weld as shown in the other picture attached. Should I be getting a smaller diameter rope for this task? What diameter rope are people typically using for this installation?
1949/50 3600 Project
Follow in Project Journals
WICruiser #1583954 07/31/2025 5:52 PM
I use insulated wire. Small and strong.
WICruiser #1583955 07/31/2025 6:01 PM
Your rope is too large. Use something like parachute cord, about 1/8" diameter. You should have no problems with that.
As far as getting the last corner of the glass in, you'll just need to work on stretching the rubber along it's length, not just at the corner. Maybe heat up the gasket just a bit.
WICruiser #1583956 07/31/2025 6:18 PM
Lay the whole thing out in the driveway in the sun. It'll stretch right in.
1950 Chevrolet 3100 (Ol' Roy)
WICruiser #1583957 07/31/2025 6:21 PM
Sir Searchalot
Sir Searchalot
Heat and soap. Helper.
WICruiser #1584031 08/01/2025 12:01 PM
Thank you all for the information. I will get some smaller cord and proceed to help the glass install to the rubber with lubrication and heat.
WICruiser #1584036 08/01/2025 12:44 PM
Moderator, Electrical Bay
A little Dawn dishwashing soap (the blue stuff) will help and it won't hurt the rubber. Rub a layer on the inside of the rubber. I use 1/8" cord...poly type. You didn't mention whether you have the type that includes the stainless molding. That is another discussion (for which I posted some hints & notes the last time I did one). If that is the case please make certain you install the molding first and let us know. As I said, a slightly different bit of work there.
~ Jon
WICruiser #1584045 08/01/2025 4:25 PM
If you have or can get a pair of the glass handling suction cups they make handling easier and give you some purchase when trying to manipulate the glass.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
WICruiser #1584110 08/02/2025 12:09 PM
Jon and Homer52, thank you for the additional input. I do not have the stainless molding (one less headache) but I do have the glass handling suction cups.
I also bought new rope, paracord 5/32" (that was the closest I could get to 1/8").
