4 members (TUTS 59, Forty9, mo2cyl, Stovebolt48), 39 guests, and 2 robots.
Topics128,031
Posts1,055,436
Members48,422
#1583711 07/28/2025 2:57 PM
Leo
Offline
Moderator
Moderator
My truck is a 1953 3100, engine is 261, carb is Rochester B. My throttle cable housing can be clamped but the thin inside cable cannot be fastened. The best I can do is poke it through the hole of the accelerator linkage and bend it around. Is this correct?
You need some sort of cable stop on the back side of the linkage.
Something like this:
https://www.autozone.com/collision-.../dorman-help-cable-stop-clamp/347137_0_0
1951 3100
AD Addict & Tinkerer
Here is a previous post the explains it perfectly.
Phil
Project Journals
Stovebolt Gallery Forum
Per the link that JW51 supplied, here’s a pic of my Dorman cable stop in action. And if you look way down in the pic, you will see the choke cable sporting one as well. Oh and Leo, if you are planning to visit San Francisco soon, I would give you a couple of them.
Craig
Leo
Offline
Moderator
Moderator
Thanks, looks like an easy fix...
Leo, there is already a hole in the throttle rod. You have a cotter pin in it now.
When I went to the Auto Parts store to buy the Dorman cable stops, they didn't have any in stock. I went down the street to a bike repair shop and they gave me this one. They have millions of them for brake cables. It has an Allen head set screw.
1950 Chevrolet 3100 (Ol' Roy)
Canadian tire should have the doorman cable stop in there uto help section if I remember correctly
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
