7 members (Donf, Goach2, Hanks custodian, rfs56trk, Rusted Nut, Bill Hanlon, 1 invisible),
56
Mod | | | Forums66 Topics128,176 Posts1,057,122 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2022 Posts: 29 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 29 | Working on 53 3100. Installing open rear end from Camaro. Same width and same spring perch dimensions as original. Looking at some lowering springs with offset pin to center the axle in wheel well. Does anyone have experience with these? Don't want to order and pay freight only to find out they will not work. Any help/advice is appreciated.
53 chevy 3100
| | | | | Joined: Sep 2009 Posts: 6,009 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,009 | IHPWR - It might help if you could provide the source and part number info for the springs you are considering. That or at least the proposed springs specifications so they can be checked against original spring dimensions to see if we can help answer your question. Don't forget to include an estimated or desired ride height as that's important too.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Jun 2022 Posts: 29 'Bolter | | 'Bolter Joined: Jun 2022 Posts: 29 | the springs are sold by classic industries, part D440A. they provide 3 inch drop with offset pin to center wheel when using newer open driveline. The dimensions per web page are L:56",W:4",H:4".
53 chevy 3100
| | | | | Joined: Sep 2009 Posts: 6,009 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,009 | After reading the description on the identified parts HERE it seems to indicate they are designed to specifically work for what you're indicating you want to do. Not having purchased these particular springs, I can't say if they're good, bad or indifferent. Hopefully a fellow Bolter or two has and can chime in and offer their thoughts/experiences.
