| | | Forums66 Topics128,060 Posts1,055,835 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2021 Posts: 1,365 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,365 | I am trying to install a new cowl vent seal but can not seem to get the seal between the open vent and the back of the vent cover (part that follows the cowl configuration when closed). Is there a trick to getting the seal in place or do I need to remove the vent cover, install the seal, and then reinstall the vent cover? | | | | | Joined: Mar 2014 Posts: 4,482 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,482 | I don't know how others do it, but I mark where the vent cover fit on the hardware, remove it and clean out the slot and then install the seal. Once I have it in I reinstall the cover. Hint: be careful when you close it. I usually have my wife close it slowly while I check clearance. Really easy to chip paint on the thing. A friend tells me he used to install them without removing the cover but it never worked for me. Good luck!
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Mar 2021 Posts: 246 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 246 | We had issues with top cowl vent (located between the two windshields) on our 1948 3100. We determined that the rubber seal is too hard and doesn’t compress. We found out that they sell a foam like seal, purchased it and the problem was resolved. We had the same problem with the side cowl vent, there too we purchased the softer seal and problem solved. | | | | | Joined: Nov 2021 Posts: 1,365 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,365 | TexasA&M48Truc - we you able to install the foam top cowl seal with the vent cover in place? I suspect the softer foam allowed enough compression to get it in place but I am curious.
Jon, I was hoping to avoid the problems associated with the vent cover removal and installation but it sounds like I may need to bite the bullet. | | |
