| | | Forums66 Topics128,042 Posts1,055,520 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 7 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 7 | After a recent outing (short 25 miles out and back) I noticed the tranny starting to get difficult to get into second gear, not impossible, but needing a hard pull. Second to third is fine , third to fourth is fine and vice versa is fine till third to second. Not being real mechanically inclined was wondering if there’s any suggestions as to what is going on…… Up till this trip it was working reasonably well for as old as it is
Thanks | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | You're talking about shifting from "granny gear" to 2nd, right? When I try that, I coast to a stop before I can make the shift. So I've always started in 2nd gear. My 1st or granny gear is a parking brake for me. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Aug 2001 Posts: 3,590 Moderator | | Moderator Joined: Aug 2001 Posts: 3,590 | I drive mine the same as Wally. But if you have a heavy load, start out in granny, then shift to second. If you start out with a heavy load on a hill, stay in granny until it starts to level out some. Also, try not to slip the clutch very much taking off in second.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Sounds like problems shifting down from 3rd to 2nd. At least that's how I'm reading the post. "Second to third is fine , third to fourth is fine and vice versa is fine till third to second."
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Dec 2020 Posts: 279 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 279 | What kind of oil is in it? Certain oils don't work as well as the proper mineral oil does.
1947 3600 Chevy
| | | | | Joined: Jan 2017 Posts: 7 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 7 | Cmayna is correct it’s down shifting to second from third . And its generally just before a complete stop. Maybe I’m just driving it differently lately. I very rarely use the granny first gear, usually when I pull into the garage to park. I’m due for oil change so I’ll be sure they take a look at the level. Like some of these old trucks, there are various oil leak issues. 🤷♂️ BTW, I tried to reply directly to the individuals, but appears that cant be done?
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Yes it would be good to know what type of oil you are using. I use NAPA or Tractor Supply 90W mineral oil. I have no problems down shifting from 3rd to 2nd when coming to a stop.
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Lumbersawyer has a good question. The SM420 synchros work best with mineral oil. Hypoid gear oil or synthetic oils are too slippery for the synchro to work well and any oil with sulphur may attack the bronze synchros. If you are not sure I would drain your oil and replace with 90 wt mineral oil. I did that with the SM420 in my COE and it had an immediate, albeit slight, positive effect. Your 2nd gear synchro may just be worn out which happens from too much down shifting into second.
Kent | | | | | Joined: Mar 2007 Posts: 3,374 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,374 | I have the same issue with the SM420 in my '58 1.5 ton. I have changed the gear oil, the old stuff looked like mud. I used a mixture of Diesel Fuel and ATF to clean the internals. I placed the Truck on jack stands and allowed the Transmission to turn in gear at just an idle with no load. I didn't do this for very long, 5-10 minutes at the most. I left it open to drain overnight and refilled it with 90 wt. mineral oil from Tractor Supply. I did work a lot better, but I suspect, as Kent suggested, that the second gear synchro is really worn.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | Related question - I don’t seem to have major synchro issues. I do have some gear noise in all gears but 4th.
My hunch is that an SM420 is never a silent unit, even in perfect condition, but that’s only a hunch
Anyone care to comment?
My biggest issue with my unit is the super-floppy shifter. Need to address that at some point.
1951 3100
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | My SM420 purrrrs like a kitten. Maybe I'm just used to it?
| | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | My SM420 purrrrs like a kitten. Maybe I'm just used to it? Mine isn’t terrible. Just a minor bit of whine.
1951 3100
| | | | | Joined: Mar 2007 Posts: 3,374 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,374 | I suspect that being a 1.5 ton farm Truck, "Thor" probably spent a lot of time in second gear..
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Jul 2020 Posts: 148 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 148 | Concur with LD on the 2nd gear synchro. If it shifts fine double-clutching, or at a walking speed roll that would confirm it. | | | | | Joined: Aug 2010 Posts: 600 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 600 | Even after an overhaul, my SM420 always had a little bit of gear noise, but not objectionable.
It's had 90w hypoid gear oil in it since before I owned it (I changed it back in the '90s and drained old sulfur out) so shoot, I thought that was what they were supposed to have!
When I downshift from third to second, there's always a little whine as the synchro catches up, I just don't force it and then it falls right into gear. Just like how Dad drove his (same make model year and drivetrain) dump truck. That downshifting synchro sound meant we were turning up the street to our house and were almost home.
| | | | | Joined: Jan 2017 Posts: 7 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 7 | So picking up this thread. I’ll be going with 90 w mineral oil for the tranny. Question, is the same oil fine to top up the rear end ? It’s a little leaky leaky ……
Thanks to all…….. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Though I use 90 w mineral oil for my sm420, I use Valvoline high perf. 80w-90 gear oil...... for the rear end.
| | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | FWIW ... my SM420 (paired with a 261 and running 17 in wheels and a 4.11 rear) in my '49 1-ton is quiet, even cruising at 65 MPH. I only hear a little noise in 1st gear and reverse. My truck is a low-mileage (probably less than 75k miles) 1-ton. Its had nothing but mineral oil in it since it was built.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Dec 2024 Posts: 114 'Bolter | | 'Bolter Joined: Dec 2024 Posts: 114 | So picking up this thread. I’ll be going with 90 w mineral oil for the tranny. Question, is the same oil fine to top up the rear end ? It’s a little leaky leaky ……
Thanks to all…….. I would not mix mineral oil with hypoid gear oil. It may be compatible, but I certainly wouldn’t take the chance of reducing the gear oil’s compression rating.
Geoff
1955 2nd Series 3600 235 cid, 4 sp. - Current 1979 Chevy K10 350 cid 4 sp -Sold 1955 2nd Series Wide Window 283 cid 3 sp - Totaled
| | | | | Joined: May 2015 Posts: 11,016 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,016 | So picking up this thread. I’ll be going with 90 w mineral oil for the tranny. Question, is the same oil fine to top up the rear end ? It’s a little leaky leaky ……
Thanks to all…….. Depends on the rating of the mineral oil. These trucks ran on rear axle gear oil from before GL-5 was developed. If it's straight Mineral oil without a rating like GL-4, then the service manual says "CAUTION: Straight Mineral Oil gear lubricants must not be used in Hypoid rear axles or two-speed rear axles.Save your mineral oil for the tranny. It's probably less expensive to buy the prevalent GL-5 gear oil to top off your rear axle.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
