1 members (Truckrolet), 154 guests, and 2 robots.
Topics128,149
Posts1,056,818
Members48,456
#1582681 07/14/2025 10:22 PM
I may have an opportunity to buy a split pipe exhaust setup from a 50-59 Longbed pickup and would like to know if it will drop right in my 1950 3100 pickup? I figure it’ll at least need shortened and/or modified where it curves over the axle.
Both my truck and the donor truck have a 235 with Fenton split headers so would be nice to have something plug and play.
Does anyone have experience with their interchangeability?
Thanks!
Trey Wilkins
1950 Chevrolet 3100 Five Window
1954 Chevrolet 4100 Dumptruck (Sold)
1957 Chevrolet 6400 Dumptruck
1966 Chevrolet K20 Longbed Fleetside
1966 Chevrolet C60 Grain Truck (Sold)
More pix on Photobucket
How do you define "drop in"?
As you noted, the length will be wrong and the hangers will have to be moved.
Can you make it work? Probably, with some shenanigans.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
I’m mainly concerned about fitment from the headers to under the cab (frame clearance, etc). That’s the area I’d like to be “drop in” as I expect that’s where a lot of the labor is going to be if I go to a shop to custom fabricate it.
Once it gets under the bed and back, I’m ok with, and expect, to make modifications.
I should also clarify it’s coming out of a 3 speed in the column truck and mine will have a T5. Hoping the lack of shifting linkage on mine will also help.
Thanks!
Trey Wilkins
Somewhere in those years there was a change in exhaust manifolds from straight down to an angle to clear the steering box. AD- task force era may have had other clearance differences. Any thing is possible
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
My TF has the 283, so I can't offer helpful feedback on when they changed the angle.
