1 members (WICruiser), 209 guests, and 1 robot.
Topics128,102
Posts1,056,184
Members48,436
#1582517 07/13/2025 2:41 PM
Working on my 53 Chevy 3100 truck cab. I ordered a new right side rocker panel but I see that I also need the rubber seal & retainer. I’ve searched hard but only found the right side on eBay.
1953 Chevy 153A 3/4-ton
Working on my project since 2015
Follow along in my DITY
Take a look on LMCtruck.com or classicparts.com . LMC truck has illustrations that may help you identify what you are needing.
Ron - - Dusty53
1954 Chevy 3604
It looks like LMC has been bought out.
I got the part ID out of my Chevy factory assembly manual.
It directed me to Classic truck parts.
LMC truck is still owned by Long Motor Corporation.
You must have clicked on an ad or something to get to Classic Chevy Truck.
www.lmctruck.com
1950 Chevrolet 3100 (Ol' Roy)
Sir Searchalot
Sir Searchalot
Maybe you are thinking of American Classic Trucks merging with Classic Trucks of America. When you search one it brings you to the "new" site....or it used to. A bunch of comnpanies were incorporated by Brothers Truck Parts and into Holley. Seems like Holley owns most of the aftermarket for our trucks.
I bought both sides of that rubber seal and retainer from Jim Carter Their PN's CB234 and CB239. The retainer is the same, either left or right side.
1947 3600 Chevy
I must have. Thanks!
Question, if I get a cowl panel driver side do I need the footwell piece too? I’m confused on what the footwell is or does.
Thanks!
Thanks!
It depends on what's rusted away. There's an outer cowl panel, an inner-to-outer cowl piece (which I can guarantee you'll need as they're the first thing to rust away), and an inner cowl panel (that might be what you're calling the footwell piece). The inner cowl connects to the A-pillar at the door opening, the floor panel, the toeboard panel and the inner-to-outer cowl panel. Take a look at my pics, this one shows the inner cowl panel from the inside, This shows the inner cowl panel from the outside before the inner-to-outer cowl piece is installed, This shows the inner-to-outer cowl panel in position, and finally, This shows the outer cowl panel in place.
I noticed that on Lumbersawyer's link that LMC doesn't carry the running board seal retainer.
1st is the running board seal set not have the seal retainer?
38-8901 includes the running board seal & seal attaching plate.
It gets confusing as to where I look.
Wanted to send you a picture of the inside & outside panel on my truck. Left & right side.
I know I need to cover & fill in holes to prevent water & trash from entering from the outside but I’m thinking I’ll just add to the existing inner panel to seal it off.
The inner panels are not weight bearing?
You know I’m not professional but I want to do an adequate job on the floor pan & foot pan. I made the two pans out of 16 ga steel & plan to screw them down then seal up the seam that joins the two. Then add the two panels.
Not to cause confusion here but after finding the nice pans on LMC I’m thinking about buying those pans.
It’s all going to be covered up with quieting layers & carpet anyway…
I think the running board seal set 30-2330 on Lumbersawyer's link is just the rubber but it appears that what you found with the rocker panel also includes the running board seal and its retainer. That's good.
Your floor pan patches look decent, especially if they're 16 gauge, which is heavier than stock.
The attached picture of yours with the red line added shows where the inner-to-outer cowl piece connects to the inner cowl panel. That's going to compromise strength a bit if not fixed. I'd recommend that you replace the inner cowl, inner-to-outer cowl, and outer cowl on both sides. You have some serious rust going on.
I'd also recommend that you start a thread for all this in the DIY Gallery HERE That'll get everything in one place on your project, rather than piecemail in various forums (you already have two threads here in Paint and Body.)
Can you help me locate the best cowls that I need? I see under LMC Steel Bidy Patch Panels, # 13, 14 & 12 & 11 possibly?
There are other cowl panels on other places but these look better.
Thanks!
Those would work for you. The inner cowl (footwell) panels # 13 and 14 look more complete than the ones I used, I replaced only the lower portion of mine, but you can figure out where you need to replace and cut off the part you don't need. Just cut away the part that's rusted till you get to solid metal. 9 and 10 are the complete outer cowl panels, but you may be able to use the shorter ones if the rust doesn't get up that high but they're only a couple bucks less than the complete panels, so I'd get the full panels.
