0 members (), 110 guests, and 4 robots.
Topics128,183
Posts1,057,264
Members48,467
I have a '51 Chevy 3100 that I put in a 292 inline 6 and am now installing the brake power booster in the firewall. This booster (on the fender of one picture) came in the bucket of parts, with the truck purchase several years ago. I also loosely installed a universal hanging dual pedal kit that straddles the steering column. My problem is, the booster mounts over the air cleaner, is low and just doesn't look correct (white paper on firewall). Has anyone on the forum experienced this problem and what are my possible solutions?
I can make this work as is, but I don't like the booster looking like it's resting on the air cleaner.
Any help, comment or suggestions would be greatly appreciated.
Booster placement and pedal kit.
Pedal kit
51Gib - Welcome back! I think your topic might fit best and get more responses and suggestions in the HiPo Shop as your project involves the later 292 (which looks really nice BTW) and the relocated pedal assembly and brake components, so it's been moved there.
I'm sure others will be along soon to offer some thoughts, comments and suggestions to try and help you with this. wink
~ Dan
1951 Chevy 3 window 3100
How about using an air cleaner with an oval shape instead of that big round one? Maybe redesign the oval base with the inlet near one end instead of the middle?
1 Offline
Have you looked at offset based air cleaners?
Use a snorkel air intake and put the filter over in the front driver side area over the generator.
1950 Chevrolet 3100 (Ol' Roy)
I thought about all the air cleaner options (this big ol round one came with the carb purchase) but I would really like to get the booster over to the fender closer. With this universal assembly I would need to cut and bend the pedal brackets plus they need extended anyway. They are too high up. Has anyone done that before? I need to keep that brake pedal to the right of the steering column.
1 Offline
Different swingarm assembly from 1967 Chevelle.
Last edited by Gdads51; 07/09/2025 1:05 PM. Reason: fix to allow for picture to display
Crusty Old Sarge
Crusty Old Sarge
Take a look at Speedway. They have several different setup options for Hot Rod builds and Street Rods. I have even seen a bracket on their sit for a 90 degree mount.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Perhaps this CPP Offset Power Brake Booster Kit, which says it moves everything 1-1/2" towards the drive side and 2" up (from the normal straight out position) would give you enough clearance? It's designed for 1948-54 Full Size cars, but I think headscratch it could be possibly adapted to your planned application. Picture below shows the rear view of the unit to show the offset bracket and rod assembly.
~ Dan
Craig also has a good suggestion on looking at Speedway stuff. Here's a Speedway Bracket Kit that could be adapted that raises the booster/master cylinder. Nothing in the web page indicates how much the offset "up" is, but a SWAG looks to be about 1-1/2" or so. It' doesn't do anything for moving the unit to the side though. frown
~ Dan
