1 members (Cosmo), 84 guests, and 3 robots.
Topics128,054
Posts1,055,779
#158211 08/09/2006 11:04 PM
Anyone have a good used or new A/C manifold for R-12?
Anyone have any R-12 for sale?
Mike
#158212 08/12/2006 5:47 AM
Why are you not using 134A?
#158213 08/12/2006 2:02 PM
Well, I have an old Corvette that I want to keep original. Plus I don't have the money to convert it to 134a. When you add in all the components, it gets expensive.
#158214 08/12/2006 3:22 PM
I just screw on the r134a adapters, charge, then remove the adapters,,brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#158215 08/12/2006 3:26 PM
car quest sales a r12 sustitute.you will have to vacumm out the system.
64 c10
89 rs
62 econoline
50 ford coupe
#158216 08/12/2006 4:23 PM
First of all you can't mix the two types and you also have to replace the accumulator, seals, expansion valve and hoses to do it right. Why mess with it when I can do it with r12.
Hey, if anyone has a vacuum pump, I'm also interested.
#158217 08/13/2006 2:21 AM
R12 has been pretty much phased out. It's also very expensive when you do find it, and you have to be licensed with MACS to purchase it. From what I've seen, you can use the substitutes as a drop in. Besides, you most likely need to replace the O-rings and other seals anyway, so why not evacuate it and do the conversion? It'll be cheaper in the long run than trying to hunt down R12.
Bill Burmeister
Moderated by  MNSmith
