1 members (Hotrod Lincoln),
60
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | Anyone have a good used or new A/C manifold for R-12?
Anyone have any R-12 for sale?
Mike | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Why are you not using 134A? | | | | | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | Well, I have an old Corvette that I want to keep original. Plus I don't have the money to convert it to 134a. When you add in all the components, it gets expensive. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I just screw on the r134a adapters, charge, then remove the adapters,,brian | | | | | Joined: Jul 2006 Posts: 49 Member | | Member Joined: Jul 2006 Posts: 49 | car quest sales a r12 sustitute.you will have to vacumm out the system.
64 c10 89 rs 62 econoline 50 ford coupe
| | | | | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | First of all you can't mix the two types and you also have to replace the accumulator, seals, expansion valve and hoses to do it right. Why mess with it when I can do it with r12.
Hey, if anyone has a vacuum pump, I'm also interested. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | R12 has been pretty much phased out. It's also very expensive when you do find it, and you have to be licensed with MACS to purchase it. From what I've seen, you can use the substitutes as a drop in. Besides, you most likely need to replace the O-rings and other seals anyway, so why not evacuate it and do the conversion? It'll be cheaper in the long run than trying to hunt down R12.
Bill Burmeister | | |
