| | | Forums66 Topics128,055 Posts1,055,785 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | Has anyone ever relocated their original gas tank and mounted it under the box? Just curious if it is possible.
Elmo | | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | What vintage truck are you asking about?
I did that for my 58, but I don't know if that experience is applicable to your question. | | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | Mine is the 1953 Chevrolet 3600 3/4 ton The reason I am asking is because my gas tank is practically brand new. So if it is possible, I'd like to mount it between the rails. And just use it. I guess I will have to do some measuring tonight and figure it out.
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | The 3600 has narrower frame rails than the 3100/3200. I vaguely recall someone doing a fuel tank relocation on one, but I can't think of who that was. | | | | | Joined: Nov 2021 Posts: 1,362 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,362 | I think the behind the seat tank is very tall compared to the space available under the bed to mount it. The under bed fuel tanks that were used in earlier models were shorter and wider to fit the space and provide the capacity desired. | | |
