7 members (Peggy M, walter74, moparguy, NJC, HandyAndy, Oswald, 1 invisible),
137
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | My 47 is still 6v. It runs great and I rebuilt the generator and installed a new voltage regulator when I built it 2 years ago. I rarely have it out at night but I noticed when I turn the headlights on the Amp guage moves to approxemetly minus 10 on a 0 to 35 scale. Does this mean that with the headlights on I am drawing my battery down or does this just show I am drawing amps from the system. If it is a draw on my battery, what do I need to do to resolve the issue and get my volatge regulator to properly balance things out?
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Well first of all, you say rarely have it out. So battery may be the issue. Ammeter needle should show a charge for a little while then settle in center area. So two tests need to give a direction to go next. 1. Measure voltage across battery posts before starting. 2. Measure voltage across battery posts at high idle.
Report
Could just be corroded cable clamps, posts, cables, other connections. Neg and Pos. Or of course, bad battery, bad charging components. Bad grounds. Need the two tests first,
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Dave, Yes, you are drawing your battery down. You don't say what your engine rpm is when this happens. It is normal at idle. If this is happening while driving, for example high gear at 35 mph, that is not normal. If not normal then follow Bartamos's advice. Kent | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Kent is very knowledgeable in that era and others. He does extremely fine work. I visited his "auto museum" when he was kind enough to give me a TF part.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I said I don't have it out at night much. I don't use my headlights very often. I will do the suggested test. I will also test drive and see if it does it at higher RPMs. I was parked with it at about 1000 RPMs.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Ok I misunderstood. Now that I have re-read....Do you have "normal" ammeter readings in the day? How many hours per week/month?
Repeating what has been said......Other than the starter at 300+ A, the headlights draw the most. With sealed beams about 100A on hi beam. The battery will get recharged pretty quickly after start. The old faithful test is during the day, drive it and observe ammeter. Then switch on headlights and observe. Should be "normal" (settling needle at middle or slight charge), then when headlights go on, needle should tick to discharge and creep back to middle or slight charge within a fairly short time. That test and the other two will expose the issue more clearly.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | I don't think I've ever seen a set of 6V headlights pull more than 20 amps or so, (120 Watts, not amps) even on high beam. With a 30 amp generator, almost all the gen output will be consumed by the headlights and ignition, leaving very little capacity left over to recharge the battery. You should see the ammeter deflect very slightly to the "charge" side at highway speed with the high beam headlight on. Jerry
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You are right Jerry. I did get mixed up. Hope it's not terminal. Was thinking 12V/100 watts. (8.3A). thanks
Sorry Dave, was a Big Beautiful Mistake
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I will need to road test it to see what happens with the amp meter. In regards to battery and corroded terminals I have a new Optima battery and new cables. Everything might be working as expected. I was in the driveway and just started the truck because it had been sitting for two weeks. When I saw the amp gauge reading I started second guessing if I really knew what an amp meter was telling me.
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | No need to do a road test, just pull the throttle out to speed up the engine.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Yes, do tests 1. and 2. And give us that report. You need a multimeter. After that, if you feel like getting up to higher and variable RPM's, go for a drive.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | Test 1 - 5.85 volts. Test 2 1000 rpms -5.84 2500 rpms - 5.84
Doesn't sound good
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | When was the last time you adjusted your voltage regulator? | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Did you run the above tests against a fully charged battery (overnight or longer on a low current battery charger)? If not, they're pretty meaningless, as the condition of the battery, not the voltage regulator or generator, controls the final voltage. The terminal voltage of a fully charged, good condition 6V battery should be 6.3V or so with engine not running. Voltage from a properly adjusted voltage regulator at cruise speed against a good battery should be 7.3-7.5 volts. Jerry
| | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I charged the battery all day yesterday on a trickle charge. It showed at 100%. I then started and saw the draw on the battery. I have never adjusted the voltage regulator. I didn't know it was adjustable. It is new and I did polorize it. Could running it for about 10 minutes and turning on the headlights have drained it from a full charge down to 5.85v. I am putting the charger back on to make sure it is fully charged.
| | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | There are two kinds of voltage regulator- - - -"Delco-Remy" and "WRONG!" I'd rather have a good condition, properly adjusted 70 year old Delco than a wheelbarrow full of offshore made junk ones. Their failure rate, right out of the box, is somewhere around 50%. www.ebay.com/itm/157140205091?Try connecting a jumper wire from the regulator "F" terminal to ground, and raise the RPM slightly. That should put the generator into full output and raise the voltage at the "ARM" terminal to 7+ volts. If the cutout relay is working properly, the voltage at the battery posts should also rise noticeably. Don't rev the engine much above a fast idle, as that will overload the generator. Jerry
| | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | The voltage regulator I installed is NOS. The box was falling apart and it is clearly a NOS regulator. Not a new offshore aftermarket. I will test the regulator output | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | Okay. Issue resolved. Thanks everyone for your input. I adjusted the regulator by bend the tension spring arm. Current output at battery post - 600 rpms - 6.2 to 6.5 volts 2500 rpms 7.35 volts 600 rpms with headlights on - 3 - 5 amps draw to negative side on amp meter. Any acceleration moves the amp meter needle to 3-5 amps positive side. Volts at battery 600 rpms lights on 5.8 volts 2500 rpm with headlights on 6.8 to 7.2 volts | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Try cleaning the points by scrubbing them with a piece of index card, or a clean business card (NOT a file or sandpaper!) The points behind the ARM and FLD terminals are pure silver, and they can be scratched easily. They have a slight wiping action as they operate to be somewhat self cleaning, and even tiny scratches will make them stick. If you test the circuit between the FLD terminal and the regulator base with an ohmmeter with all the wires disconnected, there should be almost zero resistance. Opening either one of the spring-closed points with the ohmmeter connected will result in a reading of 5-10 ohms. The point sets behind the FLD and ARM terminals are connected in series, so opening either one will reduce the generator output to almost zero. Those points vibrate several times a second in normal operation to control current and voltage. Dirty or corroded points on either set of contacts will drop the generator output to zero. The third contact set behind the BAT terminal is a cutout relay that disconnects the generator from the battery when the engine stops EDIT: looks like you solved the problem while I was typing! Good show! Jerry
