| | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | As I understand it, the 292 uses a bypass hose for the coolant to flow straight from the thermostat housing back to the water pump, whereas in the 230/250 this exchange occurs via an internal passage? I assume this allows a higher volume of coolant flow for the 292?
Kevin 1965 Chevy C10 Longbed Fleetside
| | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | If I remember correctly, the 292 block is taller but the water pump would be in the same location as the 230/250 to be centered with the radiator/core support. The bypass could be installed to make up the difference. My 66 C20 w/292 also had a much larger radiator than a C10 with a 250. Fred
