2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
I'm looking for wheel studs for my 1.5 ton 1940 Chevy truck. I will be drilling out the other 5 wheel studs to have a 10 bolt front wheel.
1942 Ford GPW
1943 Ford GPW
T33 jet
MD500 Little bird Helicopter
1940 LRDG WA truck
1940 LRDG WB truck
Sorry I cant help you on finding new studs, but wanted to inform you that the original studs are pressed in so you may not want to drill. Replacement hubs may be hard to source so proceed with care!
Lots more pictures
Thats not a problem . I have access to all that. I just need the studs. On the back of the original stud they were tacted in place by a welder.
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
regiis - Here's some snapshots of info from the 1929-54 Chevrolet Master Parts and Accessories Catalog P&A 30 March 1954 that provide details on the original stud GM# 3683850 and specific dimensions for your truck.
You should be able to use the dimension data to search and find a suitable stud. Good luck with your search.
~ Dan
1951 Chevy 3 window 3100
Crusty Old Sarge
Crusty Old Sarge
Just a question. Why do you need to have 10 lug front hubs?
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
To be historically correct on my 1940 British LRDG truck build.
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
Crusty Old Sarge
Crusty Old Sarge
Now that is COOL.. cool
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
H Online: Content
I'd suggest finding a stud with the right thread and length, and a slightly larger swage knurl, and drill/ream all the holes in the hub to match the stud.
Here is some more truck porn.
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
I found a Dorman number 610-303 I will check that out tomorrow.
On Auto Zone site.
Last edited by Peggy M; 06/27/2025 12:08 AM. Reason: Remove tracker and make it a hot link
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
I found them. Dorman number is 610-303.1 Autozone has them. After you install you need to put a nut on and cut them down and then remove nut to chase the threads.
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
Would love to see some pictures of the modified hubs. smile
~ Dan
By the end of the weekend I should have them done and ready for bead blasting
1942 Ford GPW
1943 Ford GPW
T33 jet
1940 LRDG WA truck
1940 LRDG WB truck
