Sorry I cant help you on finding new studs, but wanted to inform you that the original studs are pressed in so you may not want to drill. Replacement hubs may be hard to source so proceed with care!
You should be able to use the dimension data to search and find a suitable stud. Good luck with your search.
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
Just a question. Why do you need to have 10 lug front hubs?
~ Craig 1958 Viking 4400 "The Book of Thor" Read the story in the DITY 1960 Chevrolet C10 "A Family Heirloom" Follow the story in the DITY Gallery '59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
I'd suggest finding a stud with the right thread and length, and a slightly larger swage knurl, and drill/ream all the holes in the hub to match the stud. Jerry
I found them. Dorman number is 610-303.1 Autozone has them. After you install you need to put a nut on and cut them down and then remove nut to chase the threads.
1942 Ford GPW 1943 Ford GPW T33 jet MD500 Little bird Helicopter 1940 LRDG WA truck 1940 LRDG WB truck
Would love to see some pictures of the modified hubs.
