7 members (baldeagle, Hotrod Lincoln, Bill Hanlon, fonz8261, greenie-reddy, 2 invisible), 367 guests, and 4 robots.
Topics128,162
Posts1,057,068
Members48,463
U
U Offline
A while back when I was rebuilding my torque tube, I kept wondering about this bracket that sits on the bottom side. Any ideas or how it's used?
~ John in Utah
Here We Go
Follow in his DITY Bay
I believe a spring hooks in there but been long time since I had my 46....hang tight. Someone will be here shortly.
Enjoy watching your build.
U
U Offline
That's what I thought, but as my build progressed I couldn't figure out what would make sense. I first thought is was for the E-brake cables.
~ John in Utah
Here We Go
My 1950 has the same thing but nothing is hooked into it. Perhaps it wasn't used for anything in my case but they just kept making the same tube from earlier models?
1950 Chevrolet 3100 (Ol' Roy)
A quick search through some Chevy Shop and Parts Books (late 1930's-50's) indicate that is the anchor point for a Parking brake pivot plate pull back spring for trucks with pedal operated parking brakes and cars with torque tubes. Just a SWAG, but I think it was probably placed on all torque tubes as a standard construction feature, used when needed and unused when not. Just my thoughts on the subject.
~ Dan
1951 Chevy 3 window 3100
U
U Offline
Nice work Dan! I was just curious as to why it was there and if I was supposed to use it for something.
~ John in Utah
Here We Go
Leo Offline
Moderator
Moderator
It's for hanging the trouble light.
That's a good one.
Moderated by  klhansen, Rusty Rod
