1 members (baldeagle), 22 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#1580177 06/17/2025 9:16 PM
8
nothing beats a try but a failure
8 Offline
I will make this short. I have a new 6 volt battery. My 6 volt starter struggles to turn the engine. My engine is fresh. I installed a 12 volt battery only to start the engine. There is no electric in the truck. Just a 6 volt battery for the coil. Truck runs well. Question, do 6 volt systems struggle to turn the engine?
1955.1 3600 5 window 4 speed all original except the 410 gears.
In the Project Journal
87GN #1580182 06/17/2025 9:46 PM
Four of my five trucks are 6 volt and all start fine. You say your engine is "fresh" so I assume a recent rebuild. It may be tight and just require breaking in. Another possibility is that your battery cables are too small of gauge or corrosion is present on the connections. The latter is a common problem with 6 volts because the system requires twice the current of a 12 volt.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
87GN #1580196 06/17/2025 10:56 PM
No. 6 volt systems will spin over an engine just as fast as any 12v system.
Your problem is most likely found in your wiring and wiring connections.
Your battery cables MUST be 00 gauge - basically welding cable. Your grounds MUST be perfect. Disconnect the ground wire from the the starter to the frame and wire brush the connections. Swap the woven belt for a 00 gauge cable. Make sure the battery is fully charged to ~6.3-6.5 volts
1950 Chevrolet 3100 (Ol' Roy)
87GN #1580201 06/17/2025 11:22 PM
Get rid of the braided ground cable from the battery to the cab, and replace it with a piece of welder cable going to the bellhousing. Use a cable the same size from the battery + terminal to the starter switch. A smaller ground cable can be used for cab to frame and frame to engine circuits. The starter is the heaviest current draw on the vehicle, and it needs the biggest conductors. Chevy used short braided grounds for only one reason- - - -it's known as "baby chicken" engineering- - - -"CHEEP- - - -CHEEP- - - -CHEEP!!
87GN #1580275 06/18/2025 9:45 PM
8
8 Offline
You guys are the greatest. I replaced the ground with OO and the engine spins much better. Thanks Jim
87GN #1580280 06/18/2025 10:16 PM
That's great. I always cringe when people tell me their 6v system turns over the engine so slowly that they're converting the whole vehicle to 12v. It's such a waste of time and money if that's the driving force behind the conversion.
Make sure your positive starter cable is 00 also. Too thin gauge will result in the wire getting really hot during startup.
With only half the voltage of a 12v system, the 6v wiring has to be double the size in order to carry the same amperage.
