| | | Forums66 Topics128,162 Posts1,057,057 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2024 Posts: 99 'Bolter | | 'Bolter Joined: Oct 2024 Posts: 99 | Was there ever a factory one supplied?
Should I use the adapter plate that attaches to the top of the center windshield bar and then use the stud mount type of mirror? Or should I use the glue plate method on the glass? I also seen some mounted to the header piece above the windshield, but thought that might be too thin unless using a backer plate on the inside of the header. Chrome or painted frame? Trying to stay era appropriate, but going for safety also.
Thoughts and suggestions are greatly appreciated.
Last edited by Gdads51; 06/15/2025 10:45 PM. Reason: added detail to title and moved to Interiors forum
| | | | | Joined: Oct 2021 Posts: 6,941 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,941 | I would try to find something that mounts to the header since a windshield mount would look terrible, in my opinion. Off center, modern, and cheap looking.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2020 Posts: 452 'Bolter | | 'Bolter Joined: Sep 2020 Posts: 452 | Mine looks like the one from Chevs40’s https://www.chevsofthe40s.com/detai...B9od0bvRp-tdhQG_XcbqIqOsQDEV1lZYieqzF3yGI like the look of the ribbed backside, goes well with the hood side strip trim…. Came to me mounted with a bracket to the center bar of the windshield which I don’t recommend, every time I crank the windshield the mirror is out of adjustment. No sheet metal on these trucks is thin, self tapping screws or sheet metal screws will be fine, for extra bond put a bit of adhesive caulk behind the bracket first. Chuck
Hank: 46 Chev 1/2ton shortbed 2023 Miata RF Club | | | | | Joined: Oct 2024 Posts: 99 'Bolter | | 'Bolter Joined: Oct 2024 Posts: 99 | Mine looks like the one from Chevs40’s https://www.chevsofthe40s.com/detai...B9od0bvRp-tdhQG_XcbqIqOsQDEV1lZYieqzF3yGI like the look of the ribbed backside, goes well with the hood side strip trim…. Came to me mounted with a bracket to the center bar of the windshield which I don’t recommend, every time I crank the windshield the mirror is out of adjustment. No sheet metal on these trucks is thin, self tapping screws or sheet metal screws will be fine, for extra bond put a bit of adhesive caulk behind the bracket first. Chuck Thanks for the input. That was the one I picked out if I was going with a stud mounted version on the adapter. I will go with a simpler one that mounts to the headliner. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | On my '42, I mounted a 1954 Advance Design Chevy truck rear view mirror. As I recall I drilled and tapped two holes in the center of the header panel, right where there is an underlying sheet metal brace.
Kent | | |
