3 members (TUTS 59, Southerntruck, Otto Skorzeny), 133 guests, and 1 robot.
Topics128,095
Posts1,056,067
Members48,433
#1579598 06/11/2025 2:18 AM
I was heading to a BBQ with some car and truck fans in my '50 3100 with a 235 and a Carter YF2100 and lost git up and go trying to go 50 MPH or more.
I pulled out the choke until I found a sweet spot and got most of my power back. I pushed the cholke back in when I came to stops so that I wouldn't soot up my spark plugs.
The choke method worked fine the rest of the way to the party and all the way home which was fifty miles.
I figured that there was dirt in the main jet, since pulling the choke knob forced gas to be sucked from somewhere else in the carburetor.
I took it apart and found a 1/4" long skinny piece of rubber in the main jet hole nearly plugging it up completely.
That small rubber piece came off of the accelerator pump shaft seal.
If I would have had an automatic choke instead of the manual choke, I wouldn't have ever made it home that day.
I love these trucks.
Congrats on making it home. Have yet to encounter such a problem with my truck but one never knows what might happen tomorrow, etc.
Craig
I love it. The simplicity of these rigs is just the best.
Worst case…..if one were so inclined, a single flat screwdriver would have the carb apart in a couple minutes. Maybe add one wrench to that tool list if you wanted to take the carb off the manifold.
1951 3100
AD Addict & Tinkerer
No, the worst case would be (and this is what I envision would happen to me), dropping a screw/part attempting that repair.
I believe Carl did the right thing by getting it home, when he could work on it in a more controlled environment.
Phil
Project Journals
Stovebolt Gallery Forum
Yep, right down the carburetor throat. frown
... while the engine is running ....
A lot of people have wondered why these trucks have a throttle and choke cables. I just found another good use for having choke knob.
One time I had a hole form in the accelerator pump diaphragm of a YF2100 which cause an extreme rich condition to the point that it would stall at idle from an extreme rich condition.
I pulled the throttle knob out just far enough to keep the engine running while not moving. This allowed the excess gas to be burned instead of drowning my spark plugs. And, once again, I made it home just fine.
O Online: Content
I forgot to put the cotter pin/clevis pin in the gas pedal rod where it attaches to the linkage. Of course it worked its way out on the freeway and I had no response from the gas pedal. It was too hot to even hook it back up and stick a makeshift pin in place so I drove home working the throttle on the dashboard.
That was tricky to do while steering and shifting gears. I made it home - about 6 or 7 miles on the interstate and sorted it out when it cooled down.
1950 Chevrolet 3100 (Ol' Roy)
Did you grow up on a dairy farm Otto?
O Online: Content
No. Why?
You did what every dairy farmer has to do on a daily basis to keep everything going in between milking cows twice a day and pulling calves out in the middle of the night.
Back to the topic at hand please fellows. wink
~ Dan
1951 Chevy 3 window 3100
