| | | Forums66 Topics128,090 Posts1,056,443 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2024 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2024 Posts: 239 | I'm about ready to install a new bushing in the trans tail shaft. My approach is to use something a little softer than the bushing to drive it in. Maybe a piece of oak wood or maybe brass. Any thoughts?
1956 3100 three speed 6 cyl. Stock with a few upgrades. | | | | | Joined: Feb 2004 Posts: 29,829 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,829 | I just use a socket a little bigger than the outside diameter of the bushing. They're made with a bronze layer inside a steel sleeve- - - -not fragile at all. Use a short extension in the socket and a heavy dead blow mallet to do the driving. I've installed dozens of output bushings and torque converter bushings that way when I was rebuilding a lot of automatic transmissions- - - -haven't ruined one yet! Jerry
| | | | | Joined: Dec 2012 Posts: 122 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 122 | A parts store may loan or rent you a bushing tool.
A few years ago I borrowed a tool (compression tester?) from a local store and was stunned to learn it was free. Just had to leave a credit card number as collateral.
“Ye have not because ye ask not” 😉 gld | | | | | Joined: Apr 2024 Posts: 239 'Bolter | | 'Bolter Joined: Apr 2024 Posts: 239 | Jerry and Greg. Thanks very much. I've used the socket driver before but haven't done a bushing in a very long time.
