7 members (Bill Hanlon, Otto Skorzeny, 52Carl, Hotrod Lincoln, TooMany2count, chemanic, 1 invisible), 96 guests, and 2 robots.
Topics128,135
Posts1,056,418
Members48,441
I'm about ready to install a new bushing in the trans tail shaft. My approach is to use something a little softer than the bushing to drive it in. Maybe a piece of oak wood or maybe brass. Any thoughts?
1956 3100 three speed 6 cyl. Stock with a few upgrades.
H Online: Content
I just use a socket a little bigger than the outside diameter of the bushing. They're made with a bronze layer inside a steel sleeve- - - -not fragile at all. Use a short extension in the socket and a heavy dead blow mallet to do the driving. I've installed dozens of output bushings and torque converter bushings that way when I was rebuilding a lot of automatic transmissions- - - -haven't ruined one yet!
A parts store may loan or rent you a bushing tool.
A few years ago I borrowed a tool (compression tester?) from a local store and was stunned to learn it was free. Just had to leave a credit card number as collateral.
“Ye have not because ye ask not” 😉
gld
Jerry and Greg. Thanks very much. I've used the socket driver before but haven't done a bushing in a very long time.
