2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#1579334 06/08/2025 2:28 PM
What is the best door seals out there for a '64 C10? I installed new seals in my '64 C10 and I have to SLAM the door to get it to shut. Don't ask the brand I installed cause I don't know. Bought 5 years ago. It's like they are too thick. Any help would be helpful. Thanks
Wrenchin away
DK - Your topic probably will get the best responses and suggestions in the Doors sub-forum in the Paint and Body Shop, so your post has been moved there for further conversation and help. smile
~ Dan
1951 Chevy 3 window 3100
RLB Offline
Welcome to the club. Almost all of us have that problem. On my 66 C 10, I switched to Precision door seals. They were much better than whatever I had installed the first time. Still takes a firm hand closing the door though. Also, wiping the seals down from time to time with silicone lubricant seems to help too. Another top name I hear but haven't tried is Steele Rubber products.
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
Do I search on stovevolt or maybe other site on Honda Civic hatchback door seals. I don't recall which year range, but many have used that seal with a more pleasing result. I am not in a current position to search and find but if you do the thread should be there.
~ HB
1962 Chevrolet C10
1962 Suburban
I think this might be one of the discussion at fellow truck site 67-72chevytrucks that Hambone is pointing towards. It talks about using the Honda door seals in place of the too big reproduction stuff. Lots of mostly on-topic reading that may offer some help for your predicament. Seems to cover both the 1966 and earlier, as well as 67-72 trucks. smile
~ Dan
RLB Offline
I had gathered what I think are the correct Honda #’s. Right side 72315-SVA-A01Z A. Left side 72355-SVA-A01Z A. I didn’t order them cause it seemed like some were removing them (for one reason or another) & going back to original style. I guess it’s a matter of doing your research, paying your money & take your chances
HiPo
Do you have any profile pictures and dimensions of the Honda part? That would tell you everything you needed to know when compared to the style you have now.
1950 Chevrolet 3100 (Ol' Roy)
RLB Offline
No, I don’t.
HiPo
