5 members (1955 1 Series, Oswald, klhansen, John Dlugos, 1 invisible), 277 guests, and 1 robot.
Topics128,101
Posts1,056,179
Members48,436
#1578687 06/01/2025 6:56 PM
I strongly suspect they have neutered the old-school green coolant. Seems to lose its anti-corrosion properties in just over a year. At least that has been the case for me.
A lot of the new yellow stuff is advertised as 10 year life. I wouldn’t push it that long but wonder if I might get longer from it.
Anyone running the yellow flavor in their Stovebolt?
1951 3100
When you say "yellow", what type do you mean?
The only one I am familiar with as yellow is the prestne universal stuff.
Do you mean dex-cool? It is the modern GM coolant that is orange-ish red.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Task Force Truck
Follow in the DITY Gallery
1959 3200 Task Force
The Ballad of Enkidu
The yellow stuff uses some sort of organic additive while the green stuff uses an inorganic additive. They're both ethylene glycol based, however.
Supposedly the yellow is meant for longer life. I generally try to stick with the tried and true green ethylene glycol.
1950 Chevrolet 3100 (Ol' Roy)
Yes….that. I think there are some generic version but the universal as Prestone sells.
1951 3100
Moderator, Electrical Bay
I'm using the Prestone yellow-ish stuff and it seems okay. I could not find any of the undiluted green stuff around here, asked a friend who manages an O'Reilly's store and he said they usually had it but there was some sort of supply chain issue at the time I was buying it. I'm not certain there is much difference to be honest. The Prestone yellow said it was compatible with just about anything.
~ Jon
FYI, Undiluted green is often scarce around here too. I've taken to ordering several gallons at a time from Rock Auto. It's less than $8 per gal for FVP or $969 for Zerex. Even with shipping it's cheaper than the local auto parts stores. Every color of the rainbow.
https://www.rockauto.com/en/tools/cooling+system,fluid+/+chemical,coolant+/+antifreeze,11393
Does anyone know why we had green ethylene glycol for decades , then suddenly we have 10+ different colors/blends?
What precipitated this and what are the differences?
Green coolant uses Inorganic Additive Technology for corrosion protection. There is also Organic Acid Technology and Hybrid Organic Acid Technology, a combination of IAT and OAT. I think the different colors are the manufacturer's attempt to identify the differences in corrosion protection technology. Back in the 20's and 30's antifreeze was alcohol based.
[on edit] Here is a good reference on coolants.
7
7 Offline
The only time I needed the yellow was for a generator with the Ford 4.2 engine, cast iron block and aluminum heads, the yellow was the spec antifreeze.
