| | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,686 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,686 | I strongly suspect they have neutered the old-school green coolant. Seems to lose its anti-corrosion properties in just over a year. At least that has been the case for me.
A lot of the new yellow stuff is advertised as 10 year life. I wouldn’t push it that long but wonder if I might get longer from it.
Anyone running the yellow flavor in their Stovebolt?
1951 3100
| | | | | Joined: Jan 2019 Posts: 2,242 Herder of Cats, Goats, and Sheep (moderator) | | Herder of Cats, Goats, and Sheep (moderator) Joined: Jan 2019 Posts: 2,242 | When you say "yellow", what type do you mean?
The only one I am familiar with as yellow is the prestne universal stuff.
Do you mean dex-cool? It is the modern GM coolant that is orange-ish red. | | | | | Joined: Oct 2021 Posts: 6,802 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,802 | The yellow stuff uses some sort of organic additive while the green stuff uses an inorganic additive. They're both ethylene glycol based, however.
Supposedly the yellow is meant for longer life. I generally try to stick with the tried and true green ethylene glycol.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Jan 2014 Posts: 3,686 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,686 | When you say "yellow", what type do you mean?
Do you mean dex-cool? It is the modern GM coolant that is orange-ish red. Yes….that. I think there are some generic version but the universal as Prestone sells.
1951 3100
| | | | | Joined: Mar 2014 Posts: 4,489 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,489 | I'm using the Prestone yellow-ish stuff and it seems okay. I could not find any of the undiluted green stuff around here, asked a friend who manages an O'Reilly's store and he said they usually had it but there was some sort of supply chain issue at the time I was buying it. I'm not certain there is much difference to be honest. The Prestone yellow said it was compatible with just about anything.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Oct 2021 Posts: 6,802 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,802 | FYI, Undiluted green is often scarce around here too. I've taken to ordering several gallons at a time from Rock Auto. It's less than $8 per gal for FVP or $969 for Zerex. Even with shipping it's cheaper than the local auto parts stores. Every color of the rainbow.
https://www.rockauto.com/en/tools/cooling+system,fluid+/+chemical,coolant+/+antifreeze,11393
| | | | | Joined: Oct 2021 Posts: 6,802 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,802 | Does anyone know why we had green ethylene glycol for decades , then suddenly we have 10+ different colors/blends?
What precipitated this and what are the differences?
| | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | Green coolant uses Inorganic Additive Technology for corrosion protection. There is also Organic Acid Technology and Hybrid Organic Acid Technology, a combination of IAT and OAT. I think the different colors are the manufacturer's attempt to identify the differences in corrosion protection technology. Back in the 20's and 30's antifreeze was alcohol based. [on edit] Here is a good reference on coolants.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | The only time I needed the yellow was for a generator with the Ford 4.2 engine, cast iron block and aluminum heads, the yellow was the spec antifreeze.
