5 members (32Fordpuchoptop, 55shaker, TUTS 59, panel fan, UtahYork), 74 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
#1578580 05/31/2025 12:18 PM
Has anyone used Portawalls? Do they work? A few reviews on Amazon complained about the tire bleeding through and staining the Portawall. I want to keep my wide whitewalls but switch to a tubeless radial tire. The cost for a specialty tire compared to a standard tire and adding Portawalls is significant but I don't want to throw money away on a solution that I won't be happy with.
Dave from Northern Kentucky
My 54 3100
dgrinnan #1578586 05/31/2025 3:38 PM
Insomniac
Insomniac
Previous discussion....
White walls
They are still OK.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
dgrinnan #1578674 06/01/2025 5:22 PM
Back in the 1960s when I did tire repair at a full service station, I hated those things with a purple passion! They had a bad habit of not fitting flush with the tire sidewalls, and sometimes creating rim air leaks when they were used with tubeless tires. They can also make for tricky problems with wheel balance. Maybe they've gotten better since then?
dgrinnan #1578699 06/01/2025 9:56 PM
Those are all the reasons I have been hesitant about the Portawalls. I just hate the thought of spending $300+ per tire, but I think that is the route I need to go so I don't regret it.
My 54 3100
dgrinnan #1578723 06/02/2025 1:05 AM
I agree with you.
For wide whitewall radials, go to Diamondback. www.dbtires.com
Do not buy Cokers. They are utter crap. Even Corky Coker recommends Diamondback over his own company's products if you plan on driving the vehicle instead of just showing it.
1950 Chevrolet 3100 (Ol' Roy)
