0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#1578602 05/31/2025 9:06 PM
So my old brain is not working (whats new). took my heater out of my 1952 2 ton 3 years ago, finally got around to ordering a 12 volt motor so I could put it back together. I have the round type heater core so I have a fan blade not squirrel cage, I did not mark witch way the blade goes. will the flange go facing motor or facing out. If anyone has this style and can let me know it would be great.
LorenO 1952 Truck
LorenO52VK #1578609 05/31/2025 9:45 PM
7
7 Offline
Whatever allows you to position the fan blade in the shroud, and you can access the set screw. The fan blade will move the air in the same direction no matter if the hub is inboard or outboard.
LorenO52VK #1578627 06/01/2025 1:11 AM
Maybe these will help.
1950 Chevrolet 3100 (Ol' Roy)
LorenO52VK #1578793 06/02/2025 1:37 PM
Fan blades are directional. It matters.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
LorenO52VK #1578796 06/02/2025 2:12 PM
Otto's 2nd picture shows the correct placement/facing of the fan on the motor shaft. wink
~ Dan
1951 Chevy 3 window 3100
Gdads51 #1578822 06/02/2025 6:14 PM
Thanks that showed what I needed. I will try to get over to my shop in the next few days and get it done.
LorenO 1952 Truck
Moderated by  ndkid275, Phak1
