4 members (dt235sd, 52Carl, Hotrod Lincoln, moparguy), 370 guests, and 3 robots.
Topics128,159
Posts1,057,033
Members48,460
I am about to attempt a two tone paint job. I've never tried this before. My paint is base coat / clear coat PPG Shop Line. I've never used base coat paint before either. What do I need to know about taping, timing, etc.?
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1950 Studebaker Starlight Coupe
1947 Indian Chief
1943 Indian 741
HERE is the data sheet for Shop line. Looks like you need to work fairly quickly. 45 minutes before you can tape, and then you need to clear after 20 minutes and BEFORE 24 hours.
So first color, wait 45 minutes, tape and shoot second color, then clear the whole thing.
Thanks for that info. I have never been sure whether the "Tape 45 minutes" meant that you could apply tape after 45 minutes, or whether you could remove tape after 45 minutes.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
5 Online: Content
Just make certain that all of your coats of primer and color have been applied so that they have adhered to each other before you apply tape so that you don't pull the paint off. Use the green painters tape instead of blue tape. It is less sticky.
Mike, go HERE and get the tech sheet for the actual paint you're using. Apparently there are a bunch of different Shop Line products. I just picked one that I thought was what you had. But check to be sure.
Thanks, I will do that.
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1947 Indian Chief
1943 Indian 741
