0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I need to change my dually to single rear wheel. It is the donor for my 41 gmc coe project. It's a 2001 chevy 3500 cutaway van with a 14 bolt gm rear-end. I would like to stay with the 16 inch wheels. How big are super singles. I would just like to find like wheels without the huge offset of the dually. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2016 Posts: 1,989 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,989 | One chart on the web shows the bolt pattern has not changed for many years, your 2001 should be 8x6.5. I have mounted single shallow wheels on a dually rear in an emergency and the bolt pattern was the same from the 1984 single to the 2000 dually. My 1976 K20 had 16.5" bias ply tubeless. my 1984 C20 had 16" radial tubeless, my 2000 K3500 had 16" tubeless. my 2011 2500HD has 17", all are 8 lug. You should have many options when searching for wheels, if we were closer neighbors, I would give you some of my excess wheels.
| | | | | Joined: Mar 2007 Posts: 3,389 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,389 | Super Singles are generally a 22.5" tire. It might be a challenge to find an 8 lug wheel with that large a diameter. I would contact one of the custom wheel companies and maybe just ask some questions, you shouldn't be the first to run across this situation.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I think I have found a place that will make me a couple of wheels. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Are you putting matching wheels on the front? The front hubs on a dually truck have a hub extensions that allows the truck to use the large offset rear wheels on the front (spare works on front and rear). Single rear wheel trucks don't have that extension on the front...the wheel bolts directly to the drum. If you leave the front extension on then the front tires will stick out further than the rear tires...might look funny  Mike B  | | | | | Joined: Aug 2010 Posts: 601 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 601 | There would be an awful lot of kickout too, it might drive funny with single offset wheels on dually front hubs. If you go single you will be better off finding single wheel front hubs, so that the centerline of the wheel will be where it's supposed to be in relation to the bearings and to the kingpins.
| | | | | Joined: May 2015 Posts: 11,065 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,065 | I know on 1999 and newer Ford dually trucks, the wheel extension bolts on and can be removed to attach single wheels directly to the hub. The deep offset dually wheels on the extension wind up in the same position as single pattern wheels bolted directly to the hub. Not sure if Dave's 2001 dually has that same wheel extension on the front.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
