I'm trying to match the original off-white creme color of the outer rim and two stripes on the wheel center. Searched for a paint code but I can not find anything that drills it down specifically to wheels.
These are on a '48 Chevrolet 3800 Thanks in advance
Pick1 - Give this Tech Tip on colors and codes a thorough read.
Per the GM Heritage Center 1948 Chevrolet Truck Data PDF, your wheel stripe color was DUCO Cream Medium. Extracts below from the PDF show the color selections and stripe patterns for your 1948 3800.
~ Dan 1951 Chevy 3 window 3100 Follow this story in the DITY Gallery "My Grandpa Carl's Truck and How it Became Mine" 1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
Gdads51, you are THE MAN. This pdf is a for sure keeper. I've already found a half dozen oversights (screw-ups) I will circle back on. Thanks a million.
Courtesy of my grandson I found myself in need of a door and fender for my '87 Toyota P/U. While at the paint store I asked them to look up a code for Duco Cream Medium while they were mixing Toyota Cream 557 for the '87. When the mixing was done we compared it to the old Dupont Cream color chip. The two are identical! Anyone looking for wheel paint as mentioned in this thread has this option. The Toyota Cream 557 (some Mfg. call it Light Yellow) was used throughout the 80s and early 90s
Pick1 - That's great news that you found a color match and have shared the info for anyone in need! Any chance you can get a pic of the old Dupont Cream color chip (from your paint vendor) and a corresponding color sample pic of the Toyota Cream 557? You could attach the pictures here so others can see the results too.
