5 members (JW51, C10 - C90 Bill, Gray_Ghost, Leo, Hotrod Lincoln), 111 guests, and 2 robots.
Topics128,100
Posts1,056,177
Members48,436
#1577773 05/20/2025 4:03 PM
Crusty Old Sarge
Crusty Old Sarge
It's time to get serious on my projects. I have a Harbor Freight Pressure Pot, Hood, Gloves and Apron. What I need to know is what media to use. I have used sand in the past, but it's not really recommended because of the silica dust it generates. I need to blast a couple of frames, one is bare metal, the other has some paint.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
For the frame a coarse media like slag would be good. For sheet metal use 80 grit (the finer the better) glass media.
Tut, you already know i favor the #45 fine sand. I've used it on 2 frames and found it gets in the pockets of rust leaving a real clean finish and enough tooth for most anything
..before deciding on it I tried all kinds including the "playground" sand. Buying bags of true blasting sand will ensure size of particles which prevents clog ups.
.....we bought several bags couple months ago and its now about 10 bucks a true 50 lb bag.
I get mine at the local brick/block place.
I have glass and black diamond and even 5 gal bucket of plastic but except for certain stuff, I Lwsys go back to the 45 sand.
If you have bunch of pieces drop them off going to Townsend next week and I'll blast them in my cabinet.
....after we get back!!!
......not sure what everyone else uses for pressure but I always have good luck at 90 psi on "most" stuff.
Moderated by  MNSmith
