3 members (Wally / Montana, J Lucas, tclederman), 167 guests, and 2 robots.
Topics128,201
Posts1,057,281
Members48,467
Moderated
Moderated
I have a 1936 Chevy lowcab pickup and I want to install a 235 from a 1953 Belair and use a 2005 Chevy Colorado rear end with 3.42 ratio. As I speak I have obtained a bell housing from a 1938 Chevy and the peddles, flywheel and clutch components. I know that I have to modify the front mounts as the 235 is a bit longer than the 207 and I needed at least a 1938 Bellhousing.
Now this is where I am seeking advice: If there were a way that I could but a tail shaft with an open yoke on my original transmission that would be fine with me for the time being. However if I need to obtain a different transmission such as a Chevy 4 speed from a '41+ year and then add the tail shaft for a 1 1/2 truck to give me the open yoke for the reared match up. I would welcome comments etc. I don't know of any other suitable transmission to use in this application. I would like to avoid getting another bellhousing to accommodate the bolt up of transmission
To the best of my knowledge there isn't a tail shaft housing/rear bearing carrier made for your 1936 transmission to make it an open driveshaft. Since you're swapping out the rear (I assume you're getting the springs and hangers with it) and the engine, why not put a more modern trans in as well? If you're keeping the original trans you should keep the original rear.
Are you upgrading the front brakes to match the Colorado rear brakes?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
If you're willing to sacrifice the original driveshaft and torque tube, it would be possible for a good welder/machinist to fabricate an adapter from the first few inches of that assembly and add an open universal joint yoke to it. You would need to add a crossmember and a hanger bearing behind the original transmission to do that. Some years of long wheelbase GMC 1/2 ton frames had a similar driveline extension.
May not be much help but for what it is worth I have Chevy S10 5 speed in my 54 with the orginal 235 engine. Also a nova rearend.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
