| | | Forums66 Topics128,204 Posts1,057,292 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2020 Posts: 2 Moderated | | Moderated Joined: Sep 2020 Posts: 2 | I have a 1936 Chevy lowcab pickup and I want to install a 235 from a 1953 Belair and use a 2005 Chevy Colorado rear end with 3.42 ratio. As I speak I have obtained a bell housing from a 1938 Chevy and the peddles, flywheel and clutch components. I know that I have to modify the front mounts as the 235 is a bit longer than the 207 and I needed at least a 1938 Bellhousing.
Now this is where I am seeking advice: If there were a way that I could but a tail shaft with an open yoke on my original transmission that would be fine with me for the time being. However if I need to obtain a different transmission such as a Chevy 4 speed from a '41+ year and then add the tail shaft for a 1 1/2 truck to give me the open yoke for the reared match up. I would welcome comments etc. I don't know of any other suitable transmission to use in this application. I would like to avoid getting another bellhousing to accommodate the bolt up of transmission
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | To the best of my knowledge there isn't a tail shaft housing/rear bearing carrier made for your 1936 transmission to make it an open driveshaft. Since you're swapping out the rear (I assume you're getting the springs and hangers with it) and the engine, why not put a more modern trans in as well? If you're keeping the original trans you should keep the original rear. Are you upgrading the front brakes to match the Colorado rear brakes? Mike B  | | | | | Joined: Feb 2004 Posts: 29,879 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,879 | If you're willing to sacrifice the original driveshaft and torque tube, it would be possible for a good welder/machinist to fabricate an adapter from the first few inches of that assembly and add an open universal joint yoke to it. You would need to add a crossmember and a hanger bearing behind the original transmission to do that. Some years of long wheelbase GMC 1/2 ton frames had a similar driveline extension. Jerry
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | May not be much help but for what it is worth I have Chevy S10 5 speed in my 54 with the orginal 235 engine. Also a nova rearend.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
