2 members (Bill Hanlon, Otto Skorzeny), 111 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#1577138 05/12/2025 1:13 AM
How do you tell which rear bracket goes on which side? (This is in reference to a '50 Chevy short box). I think I know but want to know for sure. I have replacements that I know came from a '50 Chevy short box. I haven't purchased running boards at this time...that would probably tell.
Chev's of the 40's AD Running Board Brackets
Above is a link to one of Chev's of the 40's pages which has a pic of the Running board brackets (pic of bracket layout below)
Last edited by Gdads51; 05/12/2025 9:22 PM. Reason: fixed link to remove tracking and added bracket pic
Craig
I have the two brackets, one from each side. I didn't take them off, just purchased them.
Here's a photo that shows the middle and rear running board brackets. The middle brackets have a small hole just below the lowest frame holes. The rear brackets have a larger oval hole between the frame holes. You'll need to zoom the photo up a bit to see them well. The rear brackets also angle toward the front of the truck a bit, which tells you which is right or left. In the Factory Assembly Manual Section 2, Sheet 2.00 shows a top view of the frame with brackets.
Thanks...I noticed the difference in angles...I assume they are that way to clear the front of the rear fender?
Nice pic Kevin. That should help a bunch, especially showing the large hole on top of the rear bracket. But more importantly, if positioned against the frame rail and pointing slightly towards the front, it must be on the correct side.
Craig
