Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (Otto Skorzeny, Ponchogl, qside, baldeagle, 2 invisible), 75 guests, and 1 robot.
Topics128,286
Posts1,058,539
Members48,491
The engine is a 1954 model 235.
Question #1: Since the truck never had a heater, I intend to get the truck running before I try to figure out if I am going to install one for my use. If I am not running a heater, is it acceptable to just plug the two places where the heater would connect? I know I could just run a hose from one to the other, but if it is not going to cause a problem, I would prefer to just plug those two openings.
Question #2: What is the small hole for in the top of the thermostat housing for?
Nick
1940 KC Model 1/2 Ton Pickup Project
(with '37-'39 Bed and what we think is a '42-'46 Frame)
Taos, New Mexico
That hole is for a clamp for the fuel and vacuum lines that run in front of the valve cover over to the carburetor. Should be tapped 1/4-20 I believe.
Thanks Kevin!
Nick
Taos, New Mexico
On question #1, I think you could do it either way. I left the nipples for the heater hoses in place and put a short loop of hose on it. But plugging the holes would work as well, I believe. There wouldn't be a bypass of the thermostat like there would be with a short loop of hose.
If plugging the holes won't cause a problem with overheating or creating a hot spot of some sort, I will probably just plug the holes.
Thanks!
Nick
Taos, New Mexico
Plug them. A heater was a dealer-installed option on a lot of vehicles back then.
Will do! Thanks all!
Nick
Taos, New Mexico
U
U Offline
Nick, Here's a pic I found with the thermostat clip.
~ John in Utah
Here We Go
Follow in his DITY Bay
Thanks John! It does look clean and secure that way.
Nick
Taos, New Mexico
