7 members (Bill Hanlon, Guitplayer, LAROKE, Cosmo, JoergK., Wayne67vert, 4tttt8), 108 guests, and 6 robots.
Topics128,180
Posts1,057,167
Members48,465
U
U Offline
I'm swapping in a 235 on the 1946 1/2Ton. I can figure out the upper hose since I can use the thermostat top from the 216 engine and they'll be the same size at both ends (1 1/4 inch). I've done some searching and I see some posts asking about a part number for a lower radiator hose that goes from 1 1/2 inch (lower radiator) to 2 inch at the water pump. Lots of suggestions on how to make a hose work, but I never see a part number or vendor that sells a ready made solution to make my life easier for this situation. Does anyone know of a ready made hose that would be plug-n-play?
Not sure I'm going to use my old radiator, but would look for a radiator that would look and fit as stock. Thanks for any help.
~ John in Utah
Here We Go
Follow in his DITY Bay
One solution would be to fit a piece of smaller hose inside the larger one to get the proper fit on the smaller outlet. If properly done and clamped, it should be leak free.
Using a short spool of smaller hose to reduce the diameter at the lower radiator nipple works, but install it dry, NO SEALER!
I did a quick search of radiator flex hoses and found one that's 1 1/2" x 1 3/4" and wasn't even trying that hard.
I'm sure you can find a 1 1/2" x 2" one with an actual diligent search. You might try going to Gates or Dayco websites. Maybe they list all their products.
I found a silicone radiator hose reducer, 2" to 1 1/2" by Pegasus Racing. Part # SR51.38
800-688-8946
1950 Chevrolet 3100 (Ol' Roy)
U
U Offline
Thanks for the input and suggestions guys!
~ John in Utah
Here We Go
On my 46 I used a piece of the smaller hose as a sleeve on the lower end of the radiator 15 years ago and it's worked fine so far.
Jim Carter has a lower radiator hose with the larger end for the later 235 (ME239). And if you don't have a 216 thermostat housing handy they have an upper hose with the larger end (ME608).
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
U
U Offline
Thanks Kent! That lower hose looks like the one I need.
~ John in Utah
Here We Go
