| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 70 Shop Shark | | Shop Shark Joined: May 2005 Posts: 70 | I got a $20 Harbor Freight drill sharpener as a gift and never used it because I thought it was a toy. Last weekend I was cleaning the garage and figured I should try it before throwing it out.
I got a real surprize because the darn thing works and I ended up sharpening all the dull/broken drills in my drill index!
I guess I have to take back my 'it's a toy' thoughts. It's not as good as a Drill Doctor, but 'gets 'er done' if you take your time.
52 Ted
illegitimi non carborundum
| | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | When I bought a drill doctor I gave my HF ones to my buds and they really like it. Nothing like a sharp drill to do a job. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think that the difference between the Drill Doctor and the less expensive ones is in the sophistication of the machine. The Drill Doctor has an offset cam arrangement that duplicates the taper of the two faces so that only the cutting edges are contacting the material directly. This cannot be achieved by simply rotating the drill in a fixed position against a grinding wheel. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you have the right model drill doctor it'll also sharpen split points, or make split points from standard bits.
Bill Burmeister | | |
