4 members (baldeagle, Forty9, Hush, tclederman), 60 guests, and 13 robots.
Topics128,020
Posts1,055,345
Members48,419
#157685 02/13/2006 9:50 PM
I got a $20 Harbor Freight drill sharpener as a gift and never used it because I thought it was a toy. Last weekend I was cleaning the garage and figured I should try it before throwing it out.
I got a real surprize because the darn thing works and I ended up sharpening all the dull/broken drills in my drill index!
I guess I have to take back my 'it's a toy' thoughts. It's not as good as a Drill Doctor, but 'gets 'er done' if you take your time.
52 Ted
illegitimi non carborundum
#157686 02/15/2006 9:39 AM
When I bought a drill doctor I gave my HF ones to my buds and they really like it. Nothing like a sharp drill to do a job.
#157687 02/20/2006 2:13 AM
I think that the difference between the Drill Doctor and the less expensive ones is in the sophistication of the machine. The Drill Doctor has an offset cam arrangement that duplicates the taper of the two faces so that only the cutting edges are contacting the material directly. This cannot be achieved by simply rotating the drill in a fixed position against a grinding wheel.
1951 1 Ton Completed
#157688 05/11/2006 12:25 AM
If you have the right model drill doctor it'll
also sharpen split points, or make split points from standard bits.
Bill Burmeister
Moderated by  MNSmith
