5 members (Phak1, WICruiser, dt235sd, GMCJammer51, Goach2), 41 guests, and 0 robots.
Topics128,196
Posts1,057,395
Members48,471
Just an FYI post, I installed LT215/85 R16 tires on the 1954 3604 yesterday and wanted to just agree with so many who had recommended this size tire........the steering is greatly improved and the ride is a lot smoother, the same old bumpy roads seem a lot smoother. The 235/65 R16 tires were a real pain when trying to steer the truck from a dead start.
Ron - - Dusty53
1954 Chevy 3604
W Online: Content
Dusty, I am trying to decide on tires and wheels for my '50 3600 and appreciate your feedback on the improvement from the LT215/85 R16 tires.
What width rim are you using these on?
1949/50 3600 Project
Follow in Project Journals
U
U Offline
I bought the same size for my build. Looking forward to taking the first drive on them hopefully later this summer.
~ John in Utah
Here We Go
Follow in his DITY Bay
LT 215/85 R16 tires fit very nicely on stock 4 1/2" rims. I run mine tubeless. I started with sand blasted rims and epoxied the rivets from the inside of the rims. I then epoxy primed and painted the rims.
I have two 3100s with this done to them and for several years now, they never lose air.
WICruiser - the Rims are 6" wide.
Ron - - Dusty53
1954 Chevy 3604
W Online: Content
Thank you Dusty. My current rims are not a viable option so I need to obtain both rims and tires. Others have suggested 5" rims over 6" but most of the tires I have reviewed specs for are measured on a 6" rim so I am glad to hear that you are happy with your combination.
I’m in exactly the same boat with ‘55.2 3600. I like the idea 235/85’s for the larger diameter to drop my rpm’s a bit, maybe power steering is in order. Good info here.
Geoff
1955 2nd Series 3600 235 cid, 4 sp. - Current
1979 Chevy K10 350 cid 4 sp -Sold
1955 2nd Series Wide Window 283 cid 3 sp - Totaled
Rusted Nut - one of the very first noticeable differences with the narrower tires 215 vs. 235 was the steering wheel effort, big difference with the 215. My "turning from a static start" is greatly improved. My recommendation - the closer to the original footprint, the better.
Ron - - Dusty53
1954 Chevy 3604
What type of wheels are you running? Where did you purchase them.
Thanks for the info.
Geoff
Rusted Nut - I'll send you a Private Message.
Ron - - Dusty53
1954 Chevy 3604
Moderator, Electrical Bay
That lesser width on the 215/85R does make a notable difference and thanks much for posting and helping to clarify this.
~ Jon
