3 members (mick53, GMCJammer51, Otto Skorzeny), 114 guests, and 3 robots.
Topics128,050
Posts1,055,646
#1576648 05/05/2025 5:41 PM
The horn cap on my '56 Chevy 3100 is super sensitive. If I even barely bump or brush it the horn honks. Is there a way to make it less sensitive. You know, where you actually need to push it to make it honk. All the horn parts are new.
1956 3100 three speed 6 cyl. Stock with a few upgrades.
Mickey,
Can you please edit and add what year your truck is? One of us probably has a blown up view of parts and might be able to walk you through what they did.
I assume it’s the 56 in your profile, but just wanted to make sure.
Chris
I'd replace the switch. $25 at Chevs of the 40s.
The link that Bill posted shows a switch that has a tab on the bottom. That goes into a slot at 5 o'clock on the TF steering wheel. The AD steering wheel has a small hole at 7 o'clock, but the repro switch that I got doesn't have the tine. Without that keeper the switch wants to rotate as you torque the steering wheel nut. In my case the switch rotated until one of the switch rivets got close to the horn button contact. It was super sensitive until I figured that out.
1947.2 Chevy Panel Truck 1-ton
In Project Journals
In the DITY Gallery
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
Thanks Walter I'm going to take a look at that. But it'll have to wait until I get it back this afternoon. Having a little tune up work done on it.
Moderated by  ndkid275, Phak1
