Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
6 members (MikeE, Ponchogl, JW51, Peggy M, homer52, TUTS 59), 561 guests, and 1 robot.
Topics126,776
Posts1,039,274
Members48,100
Most Online2,175
Jul 21st, 2025
0
0 Offline
Does anyone know how to remove the “yoke” on this
Valve off-so I can install a new seal. Thanks for any information.
Un-solder the opposite end of the valve there is a cap soldered in. Before you do see if you can see the end of the plunger. I found there to be two different ends on one it just looked like a stainless steel washer that is thin and flexes and on the other a rubber cone shaped plug. I will look to see if I have some pictures.
kevinski
1954 GMC 9300
Here are a few pictures one from Deve's tech site were there is info on the valve. I also used info from Denny Graham from this site
kevinski
1954 GMC 9300
Here are the other pics. Also I used a kit for the rubbers for a Dodge as they are the same, but came with both the required rubbers. Detroit Muscle Technologies LLC Ranco valve seal kit
kevinski
1954 GMC 9300
On another look, if you are just trying to get at the seal in your picture, the U shaped bracket on the end shown has a slit in it that you carefully pry apart to slide over the rod to get at the flat round seal.
kevinski
1954 GMC 9300
0
0 Offline
Ok, thanks for that information. I’m just replacing the seal.
Test the inner seal when you have it apart. You can pull the plunger and plug one of the inlet holes and blow in the other to see if it leaks.
kevinski
1954 GMC 9300
1 Offline
Suck and see if your tongue sticks to it. If not, there's a leak.
1951 3800 1-ton
In the DITY Gallery
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.071s Queries: 17 (0.068s) Memory: 0.6251 MB (Peak: 0.6953 MB) Data Comp: Zlib Server Time: 2025-09-22 16:14:32 UTC
Valid HTML 5 and Valid CSS
